Rust
Jessicataurus
Windsor
I need help. I have rust on the inside bottom of the door. I really need to get rid of it before the snow hit. It is only surface rust. What would be the best way of going about this?? Thank you ;)
Silver95
Niagara Region,Canada
sand it down if its just surface rust....sand it down, prime it and then repaint it, easiest would be touch up paint for the same color as the car. And after that you can either get the car oil sprayed or just do it yourself and put some grease/oil in the bottom of all the doors
Jessicataurus
Windsor
sand it with just sand paper or a sander what would you recomend?
SHO_Driver
Montreal, QC
Use a grinder to remove the rust. It really depends on how deep the rust got into the metal. The best fix would be to cut out the rust and weld in some new metal but it'll take $$$ and time. If its only on the surface then grind it down as clean as you can. Then fill, prime and paint.
Silver95
yes, the best bet would be to cut out the rusted sheet of metal and weld a new one on, but that might not be needed in this case.
Jess-I used plain ol' hand sand paper and it worked fine. just be sure to prime/paint after sanding :thumb:
pjtoledo
'ol man in the SHO
toledo,ohio,usa
If the rust is showing on the exposed inner lip, then it's already in the seam. Be sure to spray or pour something inside the door to stop or seal the rust in the seam.
Perry
DVJ38
Hartford, CT and Worc, MA
You can get a spray can of rust oleam rust inhibiter. You can get a can for $6. I have used this stuff and it kills rust, doesn't allow it to spread any further. You should do this ever after sanding and before painting, just to make sure it kills rust pockets that you thought you got out...
