Running without a cylinder
FrOsTyShO
Lemont, Illinois
You probably remember that when i had the true dual exhaust installed my car was running really rough, and then it just went away. Well, when i performed the cylinder balance test as stated on midwestsho.com the computer took out a cylinder and the sensation was almost the same as it was when the car ran rough after the exhaust change. So now i am pretty sure i was running without one or maybe two cylinders because in the test the car ran the same with 5 rough, but not as rough as when i had the problem with the exhaust. Any ideas on how i could check the cylinder firing. I have no codes duing the test as on midwestsho.com. Only a 538 which is "did not recieve goose test". That doesnt mean anything does it?
