Hello, and thank you guys for all your excellent advice. First off, I'll admit to more than a little embarassment posting here for help - I'm a full time tech and former Ford Master tech, as well as ASE and all that. But! I'm failing here to diagnose a problem with my 89 SHO. Car is a daily driver with somewhere north of 200k on it (speedo cable broke and I haven't found a replacement yet). It's running poorly at low RPM as my title states. Working with the search fuction, I've tried several things, but nothing seems amiss. I am having a severe hesitation or stumble when taking off from a stop, and some misfire under heavy throttle, but only until about 3000 RPM. My plugs are new Autolites, wires routed correctly. No damage to wires and the resistance is within spec. I'm getting no codes from the ECM currently, but I did have a code 24 for the intake temp sensor, which I have replaced. Any suggestions? I'm pulling what little hair I have left at this point.
