JRA2000TL
The Complainer
I did a search first. I get this on the 89 and had it previously on my 90. When I turn the steering wheel, it sounds like the metal column shaft is surrounded in a tight rubber material and makes a jumpy rubbing sound. I thought it was coming from the column but some search results pointed to some bearings/bushings around the strut tower. It's like something is rubbing against rubber and slipping.
Is there something I can grease?
