SHOMEUP
Got a question with these- i'm replacing the rear rubber lines and was wondering do i need any special tools- or connectors to put the new lines on...is there any tricks or things i need to know...
Just the usual flare wrenches, and be prepared to deal with rusty connections. Actually, if you cut the hoses off you may be able to put a boxed end wrench/6 point socket on the fitting,,,use this method only if desperate and struggling with rusty connections. Cutting the lines is sort of a "point of no return", try the flare wrench first.SHOMEUP:
Yes...what's problems are you having? I know my rear brake problem was a combo one. Rubber brake lines and the prop valve. Let us know so we can help.jcostantino:
What's the problem with the rear brakes?
In order for your ebrake to be fully disengaged it needs the return spring attached to the end of the ebrake cable and the caliper. Now, since you've disconnected yours you need to make sure that the lever that the ebrake cable attached to is at the full out position. You can take a flat head screwdriver to push it out. Even though the cable isn't attached it can make a difference. Although I don't think that it would cause your pedal to not return properly, it will cause your brakes to hang up or rub all the time.SHOMEUP:
Been there already- disconnected them completly...so that aint it either-
