rendyx
Yesterday and today, I discovered that my troublesome (previous fixed) RR brake was dragging. It was creating plenty of heat in the area, so I went home and jacked it up. I couldn't find anythng obvious, besides a little resistance in turning the rotor. I took the caliper apart, and looked at it. Still nothing obvious. I reassembled it, and it (same with before) would not bleed from the valve, although fluid appeared to be coming down the hose (I'm still going to make sure soon). After putting it back together, things changed a little. Now it doesn't drag much or at all, but it appears as though the caliper won't clamp down at all by pressing the petal.
I'm going to rip the caliper off, and inspect it more carefully tomorrow, along with see if I can get fluid to come out of the brake line if I disconnect it at the caliper. And other suggestions as to why this suddenly cropped up? The last 2 things I did before it began was a WOT run, then I believe I put on the parking brake after I stopped, which I then released upon returning to the car.
Any other thoughts? Seems like a bitch, but probably pretty straightforward, nothing unusual.
