I also have a problem with the engine cutting out past 1/4 throttle, however mine will absolutely not rev past 4,000rpm. My first thought was replacing the TPS, which did not help. After this i checked the pin voltage and resistance reading of all the engine sensors at the PCM, and they all checked out OK. I realized then that my valve cover O-rings had gone out filling my plug wells with oil, i cleaned off the spark plugs, and cut off both cats (which were clogged from the oil vapor)
All of this has still not resolved the issue at all.
Next im going to work on checking out the AIRC solenoid and intake runners, because of the fact that the motor will not rev past 3.5/4k i think they may be stuck closed, however i understand that this shouldnt neccassarily cause this issue.
If anybody has any other input please let me know
