Rotors
marbs
Roy/Ogden, Utah
So I have the 96 brake upgrade done and I am wondering if Drilled/slotted rotors will make a big enough differnce that I should get them. i can get a pair for around $70. :cool:
I'm also wondering about the (What is it in 91) rear brake upgrade. What is needed to do this and how well does it work? :cool:
jedhead
westminster,ca
They are only for looks. Many drilled rotors get stress crack where they are drilled. I have seen a whole pile of crack rotors over at the SHO Shop years ago.
For the vented rear brake upgrade, you need to get the rear hubs along with the rotors. I believe the calipers are the same, because I don't recall moving them from the 91 over to Matt's 93 when we ended up doing the upgrade because everything was so rusty at the rear of the 93 and I snapped the pinch bolt.
Bob
TREpaNaTion
Local Metal SHO
Minnesota
I think it there was something about them on the Midwest site if im not mistaken might want to check there. i cant remember the url to it right off hand but its all over this site if you want to do a search. I think its more of a preference really. but then again i dont really know either hopefully some others can give you better feedback.
Ishodu
With modern pads of today the holes and slots are no longer really needed. There more for looks. And like was already mentioned drilled rotors tend to crack.
marbs
Roy/Ogden, Utah
jedhead said:
They are only for looks. Many drill rotors get stress crack where they are drilled.
Bob
So are just plain slotted better or are they just the same? :cool:
Westerly, RI
Slotted rotors are supposed to keep the pads from glazing, by exposing a fresh surface of friction material on the pad when the brakes are applied. Basically, the slots supposedly cut into the pads (just a little).
Doug Lewis of FPS offers slotted Brembo rotors for a good price. Brembos seem to have the most mass to them, which is a good thing. More mass = a tighter grain in the casting, higher heat dissipation, and less chance of cracking at the slots.
TireRack, and many other places, clearly state that slotted, dimpled, drilled, anything other than solid rotors, are not to be used for track events.
For the rear upgrade, do you mean vented discs? If so, there's very little selection of good pads for the vented rear setups. At least nothing I could find, perhaps someone else has other info. The solid setup of the 93-99 cars has a very wide selection of pads, including PFC carbon metallics and Hawk HP's.
If you meant the larger 11.6 rotors on the rear, IMO, it's an aesthetic upgrade. The same size pads are used that were on the smaller setup, so swept area remains the same. The radius of the rotor increases by .75", which in theory would give you more braking power (torque=force x distance). I've driven cars with this setup and bias plugs, and they didn't really feel all that different than my 91 with the 96 brakes, stock rears, and bias plugs.
jedhead
westminster,ca
IMHO you just get faster wear on the pads. The rational for the slots to deglaze the pads. I never had problems with pads glazing so I think they are for looks too.
Bob
