92ShoOff
Hey everyone, I have been learning about this whole valve lash adjustment and I have a question for you that I could not find an answer to via the "search" feature.
If my shims have not been rotated yet and the clearance on the cam side of the shim is out of spec will simply rotating the shim and placing it in the same bucket put it back in spec? For example, say I have a 2350 shim and it's worn down on one side. From the factory that 2350 shim put the gap within spec. Will flipping over the shim simply put it back in spec? Or will I have to swap out that shim with the correct shim given when using the Valve Clearance Worksheet?
Another example: Say intake valve "A" has a gap of .013"/.3302mm. After plugging that gap into the worksheet along with the current 2400 shim size it claims that I need a new 2525 shim. Do I not want to simply flip the shim over and expect good results on that valve because of cam lobe wear? Is cam lobe wear the reason why it recommends a thicker shim now in that bucket?
Probably a stupid question, I'm sorry... but I guess you can only rotate shims when using them in whatever bucket requires that size after the Worksheet results. Also, does it look likes these shims can be used for our application? Click Here
Much thanks,
Andrew Grayson
Much thanks,
Andrew Grayson
