ringing sound... pulleys. Q.
DavidT
TN
I recently got everything back together. Been driving daily since Monday. Friday I noticed a muffled ringing sound from the accessory belt section (at idle).
When I put everything back together, I speculated if I was getting the alternator tensioner pulley too tight. If I did, would that cause the noise?
Also, is it normal for the alternator to generate heat at startup? I could feel a good amount of heat with my hand close to it.
projectSHO89
SHOless In St L
Sounds like the alternator bearings may be under-performing and due for replacement soon.
Use a stethoscope to determine exactly the source of the noise.
Steve
