Rims
scooby
knoxville
before i spend the money , i just want to double check with some of you, is this the correct size? will they fit? thank you.
Bolt Pattern: 5X114.3 OR 5X108
Offset: +45mm
SHO2NV
Not low anymore
Angola, Indiana
45mm is pushing it. They might rub the strut and that's without tires.
FWIW, I had 18x8's with a 45mm offset and had to use a 5mm spacer to push them away from the struts.
scooby
knoxville
thanks , i will think about it now , they are suppose to fit a normal taurus , so i was told they would fit the sho , i will talk to this guy some more.
scooby
knoxville
would this fit better?
RVM 517 - 17 x 7.5
Offset : + 38
Bolt Pattern : 5 x 108 ( 5 x 4.25
SHO2NV
Not low anymore
Angola, Indiana
Yup, those will fit perfect. As long as you stay between 38mm and 42mm offset you'll be fine.
1993MTXSHO
Its a Taurus...
Jersey
yeah 38 is pretty much perfect. I have a 35mm and there pushin it I have 3mm spaces incase i need them when i get bigger tires:thumb:
