fred79
I was a napa to get some anerobic gasket maker and thought I would try and asked the guy if he had roll pins. so we go look in the bins under tension pins and found a 3/16 x1-1/2 tension pin. I got them for .33$ each will they work to replace the roll pins from the differential. they seem like they are the right size but are they strong enough to be replacements?
also the permatex anerobic gasket say to use a prep spray activator is this really necesary?
I have no worries of my trans case being busted up again. Once you see, you'll prolly be convinced, too.
