Replacing Valve Cover Gaskets And Plug Well Seals
SW SHO
Boss Man
Santa Fe, NM
TK`S SHO said:
I have changed the outer tyrod ends and the pass. side cv axle.I am still getting a poping noise when I back out of the driveway.
The popping sound could be a strut mount bearing, warn or bad spring insulator, or even a weak subrame bushing.
I had a popping sound at angles too, replaced struts, mounts, insulators, springs , aluminum SFB, tie rod ends etc and propblem solved. Keep in mind I was upgrading my suspension anyway at the time. Take a look at the subframe busings. If you have the originals and you can see the rubber squeezed out or falling apart, those should be replaced too, especially before you do an alignment.
foshotime
colorado springs CO
Allow me to correct myself; Black RTV is for oil and high temp; Red RTV is for high temp; and Blue RTV is for water or coolant. :hail:
Thank You.
