Replacing the thermostat and broke a bolt !
reags8
Connecticut
I was replacing the thermostat and broke the upper stud in the thermo housing. After taking off the intake manifold I realized this stud was threaded into the housing SO with a pair of small vice grips I unthreaded from the housing. Does anyone know if I can buy just the stud and a new nut from the dealer ? ? Or where else I could get one ?
Scott
reags8
Connecticut
What am I typing in the search field ? I found just about everything for the thermo housing except stud.
Scott
ckinart
Mississauga, Ontario
reags8:
Scott
I think Steve meant to search the SHOforum for info from other members with the same problem. Have a look here and here for starters (searched using "thermostat housing stud").
The search feature on this website is a great help. My post count stays quite low since I can find most info I need by searching before asking. I do try to help where I can though! thumb
Good luck!
<small>[ August 26, 2003, 12:06 PM: Message edited by: ckinart ]</small>
reags8
Connecticut
Thanks guys - Found out the stud is 6mm x 32mm from the dealer and discontinued.Went to the local ACE hardware and got a 6mm x 31mm off the shelf for $1.95.
Brad kirk
