Greg Gieger
I own a 94 SHO with ATX. Recently I noticed a small drip of oil in my drive way. I had the car in the dealership to have the ATX serviced and they told me the oil leak was coming from the oil pan and that to fix the problem they would have to drop the oil pan which is a 4 hour job. They quoted me $429 to drop the oil pan and reseal it with heat resistant silicon since the oil pan seals are no longer available. I checked around and found the front and rear oil pan seals were available at Cincy SHO and with shipping they cost me $27. The Ford dealership quoted me 4 hours at $65 an hour. That comes to $260 so I am wondering where they are coming up with the other $169 since two large tubes of the silicone cost only $16. Anyway, I now have the front and rear oil pan seals and think I am going to just replace the seals myself. From my Chilton Manuel it tells me to remove the starter, the fly wheel cover plate and disconnect the exhaust at the Manifold connections and then I can drop the oil pan. I had to replace the starter two weeks ago so I know I can do that. Has anyone done this before and is it that hard to do?
