boat
Likes blue ones
Hey all! Well after about a 3 plus day effort, the following has all been replaced:
All 4 struts (quick struts)
LCA's
Sway Bar links (all 4)
The car rides SOOOOO much better. All of the brakes have had some work too. Now I need an alignment, and some new treads. Then 60k's front and upper. Front motor mount and new catback exhaust. That will get it back to good mechanical running condition.
I am still hearing a clunk in the left front when I turn right. I took it to Firestone for an alignment and they tell me that either the ball joint is bad on the left side or the hole in the spindle where the ball joint connects is wallered out. Which one of the 2 is more likely the case? Exactly the spindle.
They also told me my right ball joint was bad too, only b/c it could move a little bit??? What the junk??? ISN'T A BALL JOINT SUPPOSED TO MOVE A LITTLE BIT???????????
Where can I find a replacement spindle? Is this more likely a junkyard part or is it a part I can get new at an autoparts store, or even worst case a Ford Parts dept???
LCA's
