60kmaintenance
Well mine would have to be rebuided, but even then it would probably be a waste of time. Basically, some how, a lash shim was missing or got pushed down into a valve lash bucket. I really have no clue how what why where, as far as I can tell, from my exquisite care of replacing them or what was needed..... One is down in the bucket, or one got popped out; the funny thing is I can not find one that was in it originally, or in it as the replacement one.....
Any ways I have decided to swap the head with another 3.0....
I have a gasket set for the fuel rail, and I will if possible just use a head with header on it, to avoid some hanous situation like a exhaust leak from screwed up gasket. (Who has never had that when bolting on manifolds or headers, ugh) I will order a new camshaft seal, maybe a CID just because I can.... The most obviouse, a gasket for the head.
I plan to purcahse a helms for this, but as some of you have probably done it, I would like to have any special tips at hand.
Will I be able to do all of this with out removing the timing belt from the bottom pully, I just put all of that back togather.... I was hoping just remove the camshaft sprockets, and the plate behind them.
Is there any kind of gasket I need for any thing down inbetween the heads that I can not see?
