removing the front head.
rcsavage
Florida
what all hold on the front head. ive taken it completely down(intake valvle covers, head bolts, fuel rails, cams, tensioners) what else hold on the head. i can see it moving a little when i pull on it but not much and its definatly not free. help.
rcsavage
Florida
its still on but the y pipe is disconnected, shouldn't it just lift right out?
Edit: What holds on the pipe that runs to the back of the water pump? looks like this is connected somehow. should i have to take the coil pack off, i thought it lifted out together. how about the alternator?
jelloslug
Digital
Greenville, SC
The water pump vally tube is not attached to the head. The alternator bracket is attached to the front head. Did you remove the thermostat back housing?
rcsavage
Florida
thermostat housing, sits next to the cam chains on the front head correct. what holds it on. does the coil pack have to be removed to take off the thermostat housing?
jelloslug
Digital
Greenville, SC
I would remove the coil pack bracket with the coil pack attached. There are 2 bolts that hold the thermostat housing to the front head. You will see them when you remove the coil pack.
rcsavage
Florida
Thanks everyone. i got it off, it was the thermostat housing where it connects to the housing on the back head. BTW, the alternator bracket DOES NOT need to be removed to take off the front head.
