I'd like to remove the friction surface since it's down to the aluminum edge. I snapped a socket already. I'm thinking about buying an impact socket. I soaked it in 50/50 acetone atf for days. No difference. I only soaked the back side though.
When I got it the friction surface was just above the aluminum outside, then it was even after the resurface. I'm thinking the surface needs to be even with the aluminum.
I'm worried that the new style wont work since they use a nut and bolt. The back of the flywheel is stepped the nut wouldn't be making full contact with the surface.
Should I have another place resurface the flywheel and see if I can use it? The steel is just above the bolt heads.
