?Removing Cruise Control?
MADMIKE
Muskogee,oklahoma
I am wanting to removed the cruise control from my 91 model. I did a search and came up empy. Has there been a write up on this yet? I went to remove it tonight and was not sure on it so I stoped. :confused: Any help would be great. Pics would even be better. Also, Off the topic of the cruise control. In the trunk there is two boxes under the speaker area. I know one is a amp. Witch I have already removed. I am not sure what the other one is for. The box I am talking about is on the driverside. ANY help on that would be great!!! :bonk:
Thanks,Mike
projectSHO89
SHOless In St L
To remove the cruise, just disconnect it and toss it out. There shouldn't be any negative consequences. Make sure you plug the vacuum line and seal off any unused electrical connectors.
The box on the left side is for the illuminated entry, remote keyless entry, if installed, and the keyless entry system (keypad).
Steve
MADMIKE
Muskogee,oklahoma
It looked to be more then one vacuum line. So on that box...I can remove it and my key pad enrty wont work..Great I dont need that heavy box. Thanks man.
