removing center console? help!
HoustinoJillian
name's JUSTIN
usa
mebbe im blind, but i got the back part between the seats loose, but cant figure out how to get it loose from the dash? whats holding it on? i cant see/find any screws, do i have to remove something else first?
SHO92
Upper Freehold, NJ
Did you remove the screw from under the cup holder, and lift off the main center piece first? If so there are 2 nuts that hold the front of the console to the underside of the dash.
SinisterSHO
Rust free
630, IL
Are you talking just the top half of the console, or the bottom half?
For the top half, the only screw holding it down is under the cup holder, then just grab it and yank. Its going to feel like you're breaking something, but be as gentle as you can. It takes a slight tug.
The bottom half, there is a couple of screws under the pads in the cd holder part. Then there is a screw in the center just behind the shifter, and two in the front right under the radio.
HoustinoJillian
name's JUSTIN
usa
i am stoo-pid, i figured it out after going out in the garage agian after dinner... long day of work, i'm going to post about it after a shower...
