removing cam seal(the hard way)
Cocoa,Florida
ive got a set of heads that im going to use on the 3.2L im building.
problem is that the person these heads these before,RTV'd the cam seals in,and i cant get them out.they just come out in small pieces.
i need ideas?
is there somthing i can use to maybe disolve the rubber and RTV???
93rev2sev
Hockeytown
ya, brass is soft...thats why I specified it. You could try scraping the bulk of it out with some sort of stiff plastic jabby-doo.
AREA 91
PA SHO SHOP
Area 91
I put a light coating of RTV on the outside of the cam seal. The RTV fills in between the outer portion of the camshaft seal, where it meets the head. Is it overkill, mabye. Have I ever had one leak, no.;)
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Never thought of that, however be forewarned that you are driving a SHO. It will FIND a way to leak! :biggrin: But seriously, how many miles have you put on said seal?
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
i need ideas?
Why do you want to remove the seals? They don't have many miles on them.
Cocoa,Florida
well i figured if i have to buy a whole upper gasket set,i might as well.
plus if they did start to leak while the motor was in the car i would never be able to remove the seal.
AREA 91
PA SHO SHOP
Area 91
I've done at least 7 SHO engines this way with thousands of miles.:thumb:
AREA 91
PA SHO SHOP
Area 91
I can tell you that when my buddy did his cam seals, he had a light coating of engine oil on them. He thought this would help with installing then, which it did. Exactly 7 miles later the seal shot out. R & R'd the seal with a light coating of rtv, and all is well. That was 6 years ago.:thumb:
