remote trunk release
SuperHO
Mental Patient
St. Joe, MI
so i have a problem...somehow or another, the lock for my remote trunk release got pushed down. now, this normally wouldn't be an issue, except that over the winter, circumstances required that i replace my trunk lid, and with it, my trunk lock. as luck would have it, i found a rust free lid in the boneyard that came with the proper key...some can see where this is going...unfortunately, that key doesn't match the lock for the remote release. so is there a way i can disassemble the mechanism and render the lock inoperable without destroying the whole damn thing?
SinisterSHO
Rust free
630, IL
There is, James did it with a screw driver in the parking lot in Seattle Convention.
However, I have no idea how.
Devin
3.Slow
Pacific Northwest
Pull off the handles, take off the shroud, pull back the carpet, pull the lock ring off and take off the cylinder, and have it rekeyed. The only problem I had doing this was to get it off I had to grind the retaining pin off. If you don't put a retaining pin back in then the whole cylinder will come out if you unlock it.
Getting it in, out and rekeying was really easy. Luckily I worked at a locksmith at the time so I did it myself. There's only four pins from what I remember, but they are the flat pins, not the cylindrical ones.
SuperHO
Mental Patient
St. Joe, MI
what if i said i don't care if the lock still works after all is said and done? would that make a difference?
Yes, that would make a difference - in that case all you need to do is pull it apart and remove all the tumbler pins from the lock and reassemble it. Then anything you stick in there will unlock it!
edit - btw, your 'old' trunk key will still unlock this lock.
SHO.fast
Wants Boost
Littleton, CO
okay not to jack the thread or anything
but.... my trunk popper inside the car sometimes locks by itself or it seems.
It will be working fine and then suddenly it is locked?
its not a big deal cause i have the key to my trunk :wave: but its just annoying to me.
also is there a trick to getting the trunk popper to unlock easier it just doesnt seem to be that easy lol
thanks
