Remote start run time
Stealthfrc
ct
Is it possible to lengthen the time the car stays running? Currently it
Shuts off around 10mins or so is say... I havnt timed it but I'd like to make it so it won't shut off at all.
TheDailySHO
Minnesota
If you go into vehicle settings, you can select 5, 10, or 15 minutes. Assuming you have a factory installed remote start of course.
sperold
Last to Know
I don't think you will find a way, or a unit, that does not shut off after a timed period. It becomes too easy to accidently start your car in your basement level parking and gassing everyone in the house.
jmr061
WI
Owner's Manuals do exist. It explains run times in there and how you can double the run time. So you can set it to 5, 10 or 15 minutes and then double it to get 10, 20, or 30 min.
Stealthfrc
ct
i would of never of known that without you letting me know... thanks for your input....
so i don't have to worry about it shutting off after i start it. sometimes ill forget something or whatever and i walk outside and the car is off instead of staying warm.
jmr061
WI
Not a problem. And don't take what I said the wrong way either (I can see it coming off that way).
A lot of times operational questions can be answered via the owner's manual. I have a PDF one saved on my computer so I can just do key word searches. There is a lot of "unknown" info in those thick books.
2011TAURUSSEL
2014 SHO LMS Stage 1 V10
DFW Metroplex, USA
Originally Posted by SHOdded View Post
Why do you need it idling that long?
That is a valid question. We hope your're not suffering the holiday blues already and are thinking about grabbing a hose or something! J/k
As Larry the Cable Guy would say.....I don't care who you are that's funny.
A bit early into the Winter Holiday Season but funny none the less.
Stealthfrc
ct
yea.. when i asked the question i was at work and not near the manual so figured i would ask here. that is what forums are here for.
and like i said, id like it to just not shut off, sometimes ill start it before i get into the shower or what not and by the time i go to the car its off and cooling down again... its more to just eliminate that.
jmr061
WI
Set it for 15 mins and then double it...that will be the max, and you can only remote start it twice within one hour if I recall correctly.
