Redline fluid. What kind and how much?
S
shomaster
Guest
What kind of redline tranny fluid should I get and how much should I get? I've read 3qts, 12qts, and 3 gallons, so i'm pretty confused on how much to get.
Which transmission is it going into? The MTX holds 6.2 pints or 3.1 quarts. The MTX uses Redline D4 ATF. I had previuously used the Redline D4, but lost it during a clutch replacement. I have since had equlivalent service from Type F ATF and Ford Friction Modifier.
The ATX holds 25.6 pints or 12.8 quarts. I haven't checked on redline type for the ATX.
S
shomaster
Guest
Thank you. Its going into an MTX. So the Racing ATF all synthetic blend won't work? Because thats what i thought it was, so i bought it.
SHOfun 93
Euless, Tx (Fort Worth)
I purchased the type 3 redline fluid from summit racing. If you have that type it will work fine. Will need about 14 quarts to do a complete flush. Good luck. You will be very happy with it..
olympic
Saskatchewan, Canada
shomaster:
The MTX isn't as picky as the ATX in regards to oil. I would think the ATF you bought will be just fine.
munkee
Too busy...
Missoula, MT
Synthetic will work just as well as the D4 then? I did the same thing, bought the redline synthetic. Only it's not too late to exchange it yet if the other kind will work better.
nc89sho
S13 Sellout
Clemmons NC
redline makes a MTX fluid that is supposed to improve shifting alot. that's what i'm going with. eek! shoot
