red oil pressure light not working at all
RAYJAY
WHO ME ?
UNION DALE PA
ok did a search can't find what I'm looking for
on my 1993 atx wire was broken off the sending unit repaired it and still no light:oogle:
did replace the bulb not that , any Ideas anyone,
Jeff
ice111103
Make sure its connected on the other end, not just to the sending unit. If so Check the bulb. Last ditch would be making sure you got a good sending unit. I got one laying around somewhere if you need one. I have an oil pressure gauge so I have no need for it.
RAYJAY
WHO ME ?
UNION DALE PA
F-22 Raptor SHO said:
check the bulb. If it doesnt come on at key on, then the bulb could be out.
replaced the bulb all ready
thought its a one wire system ???????
Jeff
RAYJAY
WHO ME ?
UNION DALE PA
thanks for the offer I have a couple of parts cars here also installed a new sensor with fixing the wires and just have nothing
Jeff
AREA 91
PA SHO SHOP
Area 91
Jeff, isn't the 1 wire hook up tied in with the fuel injection wiring harness? If it is, mabye the grounding strap under the intake and fuel rails? Just thinking out loud.
RAYJAY
WHO ME ?
UNION DALE PA
I will have to look at that too , I did install a oil pressure gage but also want the red light for more visual on oil pressure
Jeff
ohfosho
ontario SHOwner
ontario, canada
i suspect a bad connection on the gauge cluster. my OD light does not work. i replaced the bulb, tried it before putting all back together... no go. i pulled another one of the bulb housings out of a working hole, and still no go. i didnt look to far into it because i dont turn off o/d anyway, and if i did, i would know.
p.s. yes my OD switch has been rewired and does actually work.
