I own a 95 MTX 3.0 Sho. It is at 145k mi, and has had its 120k mi tune up done. My g/f dad (who found me the car) recently decided to clean the throttle body, stating that it would improve the performance of its age. He used carb cleaner and toothbrushes to clean the throttle body from where the hose from the air filter box connects. Right where the throttle plate is. Afterwards, he put everything back together, and now it has a problem. It has a bad hesitation in the early RPM's around 1-3k and then after that it will pull like normal. Also, when idleing it will sometimes (not often) get really low, and the interior/exterior lights will dim for half a second before going back to normal. One last thing it does now that it didn't is when I shift into first, sometimes it acts like it wants to stall and then makes this loud clank noise and starts going like normal. Some background information on it since I've had it: I brought it from AZ to CA and couldn't pass emmisions. I eneded up getting new cat converters. And that fixed the problem. Its had all of its oil changes and fluids kept up. Nothing else has ever gone slightly wrong since I've owned it. I was wondering what the cause to this would be and if there was something I could do to fix it. Any help would be greatly appreciated.
