Kudzu '92
This is my first thread, so be gentle
For the first time in 5 years, my SHO is close enough to good for me to be able to register it and bring it back on the road. I installed a Quaife'd rebuilt 5sp from FPS with a SHONut Ceramic TOB, SHOBros 17lb flywheel, a Clutchmasters stg 1 clutch, and extreme reinforced motor mounts front and rear (among many other seemingly unrelated things, mostly brake and suspension related). I filled the tranny to the top of the fill hole with Pennzoil Synchromesh fluid.
I've spent just a little time breaking the car in and trying to work out the bugs, but I've come across some problems as I go through the gears (in order of importance):
1. It will grind going into fourth gear every time.
2. The car will jump from 2nd to neutral while engine braking most everytime.
3. Occasionally, 3rd gear will grind when upshifting.
4. Sometimes, when the car is stopped and the clutch is out, I get a chatter sound. If I push the clutch in and then let it out slowly while still at a stop, the noise will go away, but not always.
I've got an email in to Doug at FPS, and I'm sure he'll get back to me when he can, but I wanted to ask for your thoughts to see if I can resolve these issues myself.
A few things came out when I did my search.
1. shifter linkage could be bad
2. tranny fluid (new) might not be right for a newly rebuilt tranny
3. clutch cable could be stretched and for some reason it effects only 3rd and 4th.
4. shot synchro on my new tranny with 20 miles on it....and me with no warranty
I'm thinking of starting with the rod shifter, though I'm not sure what exactly to look for. It looks fine, it was less than a year old when I garaged the car, but my old motor mounts were shot and sometimes I had to get a little forceful with the shifter. Looks can be deceiving after all.
What suggestions do you have for me? This is a '92 MTX with 20 miles since the transaxle swap. Additionally, what other steps should I take while breaking in my rebuilt tranny.
On a side note, I want to thank the community for helping me with my project. I don't often post, but I search and read others' posts quite frequently. You've been invaluable to my project over these past few years. :thankyou:
