Dave Kegel
Hello all,
I ran into a problem I thought I'd share with the list. It could be one of the things that only happens to me (seems as though there are a lot in this category), but just in case I thought I'd warn others.
I recently replaced the rear wheel hubs on my '90. As long as you have a 36mm socket, it's a very easy job. No press or special tools needed. I did this in the hotel parking lot in Indy during the convention. I purchased the hubs from Napa. Things went well during the install, but I was lucky.
Here's the problem: Once installed, the outside of the new hub (where the wheel mounts) is just ever so slightly further inboard then the OEM hub. The problem this causes is that a brand new, full thickness rear rotor will hit the inside of the caliper bracket. I got lucky in Indy because my rear rotors were worn enough where they just barely fit. In fact, the passenger side was slightly rubbing. The occasional odd noises is what prompted me to take another look when I got home. My rotors were rather beat from a previous encounter with pad rivets, so I bought a new set, which is where I ran into the problem. Just to be sure, I went to a different store and bought a second set of rear rotors, which also rubbed
What I ended up doing is taking the caliper bracket to the grinder and removed the portion of the brackets that were hitting the rotor. All seems fine now, but I wanted to let everyone know.
Please note that these were Napa hubs. A hub from AutoZone, Pep Boys, Advance, etc. may not have this issue.
Any questions, please let me know.
Dave Kegel
Dave Kegel
