LowSHO
I had a rear blowout on the freeway the other day in my '91 MTX. After a tow to a local garage (thank you, AAA!) and putting the car on the garage's lift, it was clear that the strut base had lowered enough to sit on the tire and eat it away like a home apple-peeler.
While I was at work, the garage "fixed" the problem by taking out the Tokicos that have been on the car for 10 years and 70,000 miles and putting new KYB's (I know, I know) on the rear. He said that when he removed the strut on the side that had the blowout, the strut just fell apart, and that the base of the strut had rusted enough to let the spring contact the tire.
I now have the car at home, and it is clear that the side that had the blowout is significantly lower than the other side, more than an inch lower, measuring from the top of the rim to the highest point in the wheel well opening.
I am about to put the car in my garage and jack up the rear. Can anyone tell me what to look for? Has this happened to anyone else? A search here yielded no obvious results.
I am not an experienced mechanic, but I'm no dummy either. I've changed the fuel pump, did my own 60K, and some other step-by-step maintenance with instructions found on the Forum.
But I am afraid that when I jack the car up, I will not see the problem without some help from the experts that hang out here.
