Rear Speakers in door?
dmoo21
el oh el
St. Louis Park, MN
ive looked but i dont know if theres enough clearance for them to fit...i may need to look further cause that would be cool
-Dan
redsho
Need 4 SPEED
St. Paul, MN, USA
-Dan
Both you two have red cars & thinking the same thing I'm thinking... :)
K-Dawg
Treasure Coast, FL
Ok, went out and took a gander. Looks to be possible without too much trouble, but you are looking at fiberglass pods for sure. Would probably be easiest and look best to replace the whole carpeted area on the door panel. The window doesn't go all the way down into the door, but the the motor is stuck right there in the way, so I don't think there is enough room to have the woofer mounted in the door, especially if it has a decent sized magnet.
redsho
Need 4 SPEED
St. Paul, MN, USA
Based from what you said... it's seems like it can't be done w/o a lot of modding :oogle:
