rear power windows
94mtx
san diego
my rear windows on my 94 do not work!! the left one has never worked since i have owned it (since nov 00) but recently the right rear has stopped working. neither work from either switch. i have tried to remove the rear door panels, but have encountered ummmm resistance and did not want to break the panel!! any help or personal experiences would be appreciated.
thanks
jon
Jr's Sho
Moss Point, MS
Well do the windows go down when you use the drivers side window switch? If they work then, t sounds like it's the window switch. I have never taken off the rear panels but look for screws and small bolts and after removing the ones you see, then gently pry the panel from the door, it's held on by retainers of some kind. Then disconnect the wires from the switch and pull it out. Have fun.
Disclaimer(I've only taken the front door panels off so some info may be incorrect.) :D
SHOMA
Springfield, MA
Well, not trying to capatlize on your problem, but if indeed you need wdo motors, I have them... (they are on ebay, link to my auctions is: http://cgi6.ebay.com/ws/eBayISAPI.dll?ViewSellersOtherItems&[email protected]&completed=0&sort=3&since=-1&include=0&page=1&rows=25).... The rear door panels are as follows: I do not believe they have any screws holding them in, (possibly one where the grab handle is, but 99% sure there isnt), if you can pry your fingers under the bottom edge, and pull, they are just the little snap-in tabs all around the door panel... Either way, I hope you get it fixed, and the rear wdo motors are cake on our cars, easier than the fronts...
[email protected]
