JRA2000TL
The Complainer
I need (and have) a replacement rear motor mount for the 89. I'm pretty sure it's shot since I've tested it with the parking brake on. When I put it in R with the e-brake, and try to accelerate, the motor jumps. Makes sense as I previously had a bad front mount, which I replaced with a reinforced mount.
The other day, my brother and I were playing around with the car, and he started turning the wheel while the car was running. I witnessed the engine move "side to side", which I thought was odd.
Is this due to my broken rear mount also...or should I replace the tranny mount as well?
I still have the splash shield removed, so it's just a matter of jacking the car up, removing the bottom large bolt and 2 long, skinny bolts--doesn't look too involved. As for the tranny mount, I have no idea where it is or how to check it.
