Rear headliner creak/dashboard creak
nannho
2010 SHO
The Chi...
Have creaking coming from rear passenger side headliner. I jammed some double sided tape up there but has anone else had this? Is there a better or permanent fix? Improved tremendously but still a slight rubber run sound.
Also slight creak from center tail light plastic piece, where it meets headliner as well.
Also have a creak from under the dash directly in front of steering wheel, half way between wheel and sensor (on the dash.) When I apply a little pressure it goes away (like 1 finger slight pressure.) Otherwise it's notocable. Any tips or trick? Comes and goes. I thought it was loose rivets under hood. Taped them up by firewall but no dice. Also checked push pins on hood liner.
Both are bugging the **** out of me as when I have the radio off, I want fuckinng silence.
