rear exhaust hangers
rickshaw
Jacksonville, FL
I noticed my exhaust is starting to hang low.
Is the rear exhaust supported by rubber hangers? Are the replacements available through aftermarket or only OEM?
Thanks to all!
rickshaw
Mr Anonymous
Tire Wall
Just run a hose clamp around the rubber hanger and tighten until it gets back up to the height you want.
wuzzzer
MN Moderator
St Cloud, Minnesota
Thanks for the tip!! My passenger's side tip/muffler hung lower than the driver's side ever since I had my new mufflers put in a couple years ago. Always bugged me. I'm going to go to the hardware store tomorrow and buy a clamp! :thumb:
rickshaw
Jacksonville, FL
excellent tip Chris! I just happen to have a wide variety of stainless steel hose clamps from my jst ski parts bin!
closed!
rickshaw
wuzzzer
MN Moderator
St Cloud, Minnesota
What size clamps work? I went to the hardware store today and picked up a couple of 1 3/4" - 2 3/4" clamps. I can't install them yet because its 92 degrees out and after driving my car my exhaust is probably 1000 degrees.
wuzzzer
MN Moderator
St Cloud, Minnesota
rickshaw said:
if you zip tie aroung the rubber, it won't melt. it also looks like you'll need a 3-4" hose clamp.
rickshaw
I installed my clamp last night just before it got dark. I hooked it around the 'bar' that comes straight out from the car and then hooked around the 'hook' that is at the base of the rubber. Is this how anyone else has done it? It seemed to work fine, as I was able to tighten the clamp up enough to perfectly balance my right tip to my left.
hoboprodigy-
SMOKE
Troy, MI
2 said:
If the rubber doesnt melt why would a steel hose clamp?;)
I was talkin about the plastic zip tie.. i don't know how hot the exhaust tips get but it's one of those questions in life i'd rather not find out :D
