Rear diff cover drain plug
BamSHO
South Williamsport,PA, US
Been working on a little project here it is.
OK here is an update on my drain plug project. I drilled a 3/8 hole and reamed it out some so the bolt would fit thru easy. Then installed the bolt thru the back side of the cover outwards so I could thread the nut down onto the cover to hold it in place so I could welded it in place. Yes please, don't laugh to hard, my welding is very bad. I welded the nut onto the cover and then removed the bolt that was holding it in place. I saw this concept on an episode of one of the Powernation Tv shows. The bolt I used will be trimmed shorter so that it just barely goes past the cover as not to interfere with anything. I need to paint and finish couple other detail, but this is what I got so far.
20160225 114045 zpsomnd0cud
20160225 115549 zpskfnst1lp
20160225 125707 zpszvtkmjii
20160225 130458 zpsjt0hchvi
20160225 130508 zpsnssczba2
20160225 130524 zpsbjaxrmmb
BlueSHO
I like your thinking. Wonder if anyone sells an aftermarket cover with a drain plug..
Sent from my DROID RAZR HD using Tapatalk
BamSHO
Well here the finished product. I used a little JB Weld just to help it look little better. I took the cover to work and put some thin oil we use on the presses and NO LEAKS!, YEAH. So the will be installing the cover this week when the weather gets nicer.
20160304 150129 zpsdrqbju1a
BlueSHO
Looks good.
markathome
2010 SHO
VA
Can't wait to check this out at the Ford Nationals in June! Looks great.
Sent from my XT1094 using Tapatalk
