Rear Coil Spring rubber Insulators & question about Sway-bar-to-body bushings
JaySHOguy
Bellingham,MA
Hi guys.
Has anyone bought new rear Coil Spring rubber insulators? I am having a hard time trying to locate some...
Also, what is the part number for the Energy Suspension bushings that connect the rear sway-bar to the body?(26mm bar stock)
I'm replacing practically every bushing in the rear(minus the ones on the control arms), and I would rather just get new Insulators instead of using ones with 153,000 miles on them.
Thanks!~
FAST4DR
Don't know about the coil spring insulators but here is the # from the energy suspension bushings that I had. Energy #4.5134G
shojuan
sunny San Juan Bautista,
Jay97SHO:
I haven't bought them (still got stock struts and springs arrggggg!) but I noticed that the KYB strut bellows kits that you can get from tirerack have integral strut bumpers if that's what you're looking for.
gosho89
Vancouver, WA
Jay97SHO,
You may want to consider the moog TPR bushings for the rear 26mm bar, since the ES bushings are non-greasable and will squeak/groan over time. TPR material is less likely to squeak/groan and about the same price. So far I've had good luck with mine.
MeShoHorny
@dm1n15tr@t0r
NY
I got my insulators from FPN. I can get the part number if you need it.
I have the ES bushing- no squeaks at all thanks to marine grade silicone and teflon tape.
Moog didn't make the TPR bushing when I did my suspension. IMHO, go with TPR over poly whenever possible.
*Edit* I have the TPR on the rear sway bar and love them. I thought Kerry was talking about the front bushings for some reason. If you can find TPR for the front get them!
<small>[ May 06, 2003, 11:41 AM: Message edited by: MeShoHorny ]</small>
JaySHOguy
Bellingham,MA
If you guys can supply me with the part numbers, that would be very much appreciated! thumb
Thanks again!
MeShoHorny
@dm1n15tr@t0r
NY
Jay97SHO:
Thanks again!
F1DZ-5K617-A REAR RUBBER SPRING/STRUT INSULATOR $ 6.89 ea.
E8DZ-5414-A FRONT RUBBER SPRING/STRUT INSULATOR $ 6.99 ea.
Chis Randolph
Lafayette,IN
What are some symptoms of a bad spring/ strut insulators on a sho, and how would I know if i need to replace them on a gen3 sho.
Chris
