rear bumper
Jessicataurus
Windsor
how do i change a 95 Taurus SE bumper to a 95 SHO bumper? All i have is the SHO bumper. I can't seem to get the SE off to put the SHO on.
Do i need anything for the SHO bumper to make it fit.
Help please :confused:
Minnesho
i was wrong
MinneSHOta
just remove the 6 (i think) bolts where the impact absorbers bolt toe the bumper, then pull off, and bolt the SHO one on,
Jessicataurus
Windsor
but the bumper for the sho has different bolt paterns than the SE would that matter?
Like it has bolt holes around the wheel and there are none on the SE bumper.
Minnesho
i was wrong
MinneSHOta
it dosent matter , the bumper is not bolted on to the wheel well, what you are seeing is where the cover is bolted to the bumper itself, removing the bolts from the rear like mentioned above and then the whole assembly will slide of the rear, then just slide the SHO bumper on and bolt it on. mine had 6 bolts in the rear others may have 6 or 8
Jessicataurus
Windsor
well is there suppose to be a piece that is already attached to the fiber glass piece it's self or no??
Minnesho
i was wrong
MinneSHOta
the inner bumper support will come off with the entire cover. i'll try and get some pics tomorrow to help you out.
Jessicataurus
Windsor
ok that would be awsome if you could do that. thank you. I really wanna get this done. i am goig to work on a few more things and than i am going to put the car into a show. The help is greatly appretiated
Jessicataurus
Windsor
Bumper
:rofl:
Anyone have pics i may need some more help. Thanks
:rofl:
SHObill
'The Collector'
Rochester MI-48307Detroit
bumper covers
Jessica, the 2ndGen SHO urethane bumper cover is installed right on top of a SLO urethane bumper cover which is then attached to the bumper core support & that bolts to the body! I found that interesting after parting out a MB SHO!
AND as for meets just come through the tunnel & join the Tri-State SHO-SVT group! Feel free to call me for details.
Jessicataurus
Windsor
so even though there is nothing attached to the fiberglass bumpper i can still do it off of the SE with no problem??
