Rear brakes
LaX SHO
La Crosse, WI
I am trying to replace my rear brake pads. I have the old ones off and I am currently trying to turn the piston back into the caliper. I have been turning it for a good 15-20 minutes and it hasn't moved. I even tried cracking the bleeder screw but that still didn't work. What am I missing here?
wood_e
The dude
Ames, IA
You need to turn the piston as you push it in. There's a special tool to do this but some have used needle nose pliers to do it.
LJRuddy
Pop lock n drop
Poaceae fields
When i changed my brakes on my 94, the piston poped out and i tried to put it back in. What i did not know is if you get that piston cockeyed even by the slightest amount, you have to buy a new caliper because, more than likely, they are jammed together.... i had the misfortune of doing this myself. Be careful when putting that back together!
LaX SHO
La Crosse, WI
I was pushing in on the piston as I was turning it. I am using the needle nose plyer method which worked last time I did the brakes. I was out trying it some more and still nothing.
Redskull
Badass Mo'fo
New Haven, CT
a c-clamp and a block of wood (or old brake pad) can do the trick. It makes things alot easier if you crack you brake fluid resivoir cap a little, just enough to let the air out.
alan
dstig1
Hudson, WI
And open the bleed screw on the caliper as you are turning the piston back in. Waaay easier. You should have a small hose so you can drain it into a bottle or pan, but that is up to you. Make sure you clean any and all brake fluid off any braking surfaces before reassembling.
HighSpeed
Low Drag
Chicago, IL
alan
You want to do this for the front brakes, it won't work for the rear brakes.
If the needle nose plier won't work, you need to get the specialty tools for this job, u can rent them and get ur money back. If u use the specialty tool and it still won't budge, u need new calipers. U may want to check the other brake parts as well, if u replace everything else.
