Rear brakes just started grinding
SCOTTDW
Memphis, TN, USA
My rear brakes have just started to really make a grinding sound upon application. I am under a warranty for the calipers...but I think this is going to involve the rotors and for sure the pads. Can anyone verify the Ford part #BR35A for the pads..and should 598 be a part of this number as opposed to 601? I would like to have something to show the Service Advisor. It seems like a couple of years ago the 601 part number was to be avoided Thanks.
Scott
98SF
K&N Panel
Magnaflows 3"tips
BFGoodrich KDWS
The rear brakes are common to all Taurii with rear disc. SHOs and SLOs. At least from '93 on.
SCOTTDW
Memphis, TN, USA
Thanks Paul, I did not know that. I am taking the car in for service in the morning. Will report back....very noticable grinding..even a couple of the neighbors were gawking as I limped into the garage.
Scott
98SF
K&N Panel
Magnaflows 3" tips
BFGoodrich KDWS
mofosho
Battle Creek, MI
Cause you should be!
FWIW i changed out rear rotors and pads on my 96 this week for 75 dollars in parts and only took me an hour. Autozone sells a tool that retracts the caliper for 8 dollars. It's an easy fix!
SCOTTDW
Memphis, TN, USA
I had the front and rear pads replaced and replaced a rotor. I have a friend who owned a battery shop and has plenty of space to work on our cars. We trade goods and services...so it worked out well especially since its about 95 degrees here and I had appointments all day. Also mofosho, Mr. Burtram....you sir are Batman....keep up the good posts. I like the one hour brake jobs etc..
Scott
98SF
K&N Panel
Magnaflows 3"tips
BFGoodrich KDWS
<small>[ June 18, 2002, 09:36 PM: Message edited by: SCOTTDW ]</small>
SCOTTDW
Memphis, TN, USA
Are the BR35A and the BR35B the same front pad?
Scott
98SF
K&N Panel
Magnaflows 3"tips
BFGoodrich KDWS
<small>[ June 23, 2002, 10:28 PM: Message edited by: SCOTTDW ]</small>
SCOTTDW
Memphis, TN, USA
Thanks Brent, I thought that was the case. Kind of like the telephone equipment I sell....they just keep adding letters every year or so.
Scott
98SF
K&N Panel
Magnaflows 3"tips
BFGoodrich KDWS
hosbaldosho
