Rear Brake upgrade
Art5
white plains, NY
I'm looking for something to change my rear rotors to ventilated. I was considering 89, but they don't have ABS, for some reason hard to find the once with ABS. Anyone knows what are my alternatives?
My rear caliper is getting stuck, or maybe it's the a hose, however if I should go there, I might as well modify. Any thoughts?
shobote
Naperville, IL
The rears don't really do that much braking compared to the front so no need to ventilate. Stuck slider pins often cause the sticking caliper syndrome too. The stock 89 rear brake calipers are the better choice compared to other years and should be more than adequate.
mattsho1993
SHO owner
albion, new york
hey guys i saw something on tv where some car place was racing out a car dont remember what and the rear brakes were tiny and bigger upgrade was not available so they fabricated a front brake system for the rear how plausible is this for the SHO
38SHO
#1 Oil Abuser
North Palm Beach
a few things I might add here
first off, there is a reason why Ford SWITCHED to a solid rotor from the vented one.... when you up your performance as noted below, and are approaching rear temps that your rotor cannot handle with the proper pad heat range already installed.... then I would say it might be a good idea to switch to rear vented rotors.
second off, to improve your braking performance, switch to a stickier tire
third point- crank up your brake bias until you loose traction during braking on the rear brakes. if you are wearing out rear pads before front pads, you are doing pretty damn good in this department. Stock they will last a lot longer then the front pads, but start working them as much as the front pads or more, and they will wear out faster because they are a smaller setup. if you gotta add a little weight to the rear to help out with traction and change alignment settings have at it, the SHO can use some weight on the rear, just remeber to take some off the front while you are doing this.....
all of what I said above can damn near be negated depending on what you actually do with the car
if all you want is a good panic stop out of your car, forget about rear vented rotors, forget about hot brake temperatures(unless u are savvy at picking pads) and go with some 11.6" brakes from a gen3 SHO with the proper OEM Ford brake pad for that application on your front axle.....
if you want repeated race car type stopping power, bring on the high temps, the race pads, and the bigger rotors..... but too big can be a bad thing, you actually want some heat in your brakes.... that is why Ford whent to a solid rear rotor, to retain more heat in the rear brakes for city driving/panic stops... even race teams block off brake ducts until they find a happy median where they cool the brakes to stop overheating components, yet keep the temps up where they want them so the pad stays effective.... Nascar teams run specific tests just for these purposes on race tracks...nice to have money huh.....
Art5
white plains, NY
My car is 94 and, I'm going to use cobra brakes in the front later.Right now my car is Getting work done. I needed to change rear calipers on my other 94 so i wanted to take it from the one that i'm working one and put it on my DD, but need to get the other one off jacks. Few years back i had 95 modified and brakes sucked BIG TIME!want to do the whole thing right this time.
Art5
white plains, NY
I don't want to play with bias, because that's how i crashed my 92. rear caught up before front.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
You can get it from the 90-92 SHO.
We also have teh 11.6 upgrade at SHO Source.
pitaSHO
Why do I do this to myself?
Lewisville, TX
If your rear caliper is sticking grease the slider pins first. This may solve the issue until you can play with upgrades.
Chris K.
1993MTXSHO
Its a Taurus...
Jersey
^^ agreed.
rear upgrades are more for bling than anything.
Get the 13" cobras , then you will forget you need rear brakes.
I dunno, I'v had my 11.6 upgrade in the REAR of my car pretty dang hot. The 2 piece 12.5's up front were smoking hot as well. All that was from was a little spirited driving up and down some hills. But I definitely agree with the looks thing, the bigger brakes out back look a lot nicer.
But yes in all honesty stock rears do the job well enough if you don't track the car. Even if you do and you have it stripped down to 2800 lbs or so, they are probably OK. In all honesty the rear brake upgrade is probably more trouble then it's worth, I only have it on my car because it was there when I bought it.
BTW Art I'm the one who you've been e-mailing back and fourth for the past month or so about your cars if you didn't know that already.:wave:
Art5
white plains, NY
Thanks, Nick for all the info, you gave me. A lot of info, plus all of you guys, you help a lot with all of your info. My rear caliper bracket pin was really stuck, but now i need a tool to compress that stupid caliper(this one turns). Guys, i used to drive very ******* streets and run away from cops like crazy, just in case i would have to do something like that again, i don't want to worry about brakes. I don't even want some local"good mechanic" to touch my car, because the all suck. They'll repair your car and tomorrow it will start braking again and I would have to go back and waste my time again for the same problem, argueing.
turbo79
Saint Helens, Oregon
<snip> But yes in all honesty stock rears do the job well enough if you don't track the car. Even if you do and you have it stripped down to 2800 lbs or so, they are probably OK. In all honesty the rear brake upgrade is probably more trouble then it's worth, I only have it on my car because it was there when I bought it. ...
I know one guy who tracks his car, he has stock rears and the 13" Cobra set up, (it is lightened a bit), and the stock rears do just fine. He is a hard driver, too.
