1995 SHO ATX.
Well the reason I had to fix car was we were on a trip and i let my buddie drive to get some rest, he ended up putting it in a ditch due someone cutting him off.
The new problem was that it had broken the rear brake lines. so i went and temporarily fixed them till we got back from the trip with some rubber fuel line and clamps and blocked off the rear brakes all together. then i get home and put new lines from the front floor pan to the rear block(the one attached to the rod on the lca). ahd here is the problem. i get fluid to the block but none to the calipers. i was told load up the trunk with weight to load the valve on the block and let it gravity bleed for a day or so and that would do the trick, but it hasnt. so i am in desperate need of help. any input would be greatly appreciated.
