iselltonsofthings:
Not to be rude, but I'm trying to focus on the idea of cost savings with just a standard brake line coupler.
Here are some simple drawings that illustrate the line couplers.
Will this system work correctly by eliminating the proportioning valve entirely!
I assume that the couplers could be found at any auto parts store for under $15 for the two.
Yes/No ??
Thanks. Scott
Scott,
if you don't mind cutting, bending, and splicing brake hard-line, what you've proposed will work just fine. Have fun and just be damn meticulous, your safety and the safety of others is at stake.
The flare connectors on the four lines to the bias valve body are all different thread pitches and sizes to prevent cross-connects at the factory, so unless you want to build a forest of Metric ISO flare adapters, the best way is to cut off the OEM flare connections and make some new splices with standard flare connectors.
Please consider this advise from someone who has re-plumbed the brake systems on several track cars:
1. Don't use brass fittings in your brake system, use only steel. Brass fittings are soft and are subject to rupture at brake system pressures.
2. When flaring brake tubing, use only ISO double flares. Single flares can develop cracks around the cut edge of the tubing where its been stretched, allowing the fitting to leak and/or fail catastrophically. Buy a good double flaring tool if you don't have one.
3. Be aware that the steel brake line in your 10 year old car may be a bit brittle from age, so you want to avoid introducing new bends into it. If you have to do some serious re-routing of OEM tubing, cut out the old section and use new tubing that hasn't work-hardened. Buy a proper bending tool for the size tubing you're using.
I'm not gonna' go into the pluses and minuses of defeating the rear bias valve, its been discussed here and on other SHO lists, ad-nauseum. Use the search function if you're so inclined.
Edited for speeling and clarity...
<small>[ December 28, 2003, 12:46 PM: Message edited by: Gary M. ]</small>
