I was hoping you'd forget.
I had to do some digging.
Here's one before removal, it shows the lifting arms.
Here the assembly is removed.
Note the 5 nutserts on the Pside for reassembly.
These are the clips that retain the track to the body at the rear.
These sliders stay in the track for proper alignment.
The Spring steel insert either rusts or looses tension.
Here are the front hinge rails and retainers with bolts.
And the slider spring steel inserts from good to not so good.
The underside of the assembly.
And reinstalled.
I realize the pics aren't the best.
But that's all I can offer to the best of my memory.
I used nutserts and stainless bolts instead of rivets.
I also made my own track to body seal.
