Rattling noise
huththo
ND
Hey guys
I recently did some upgrades where i put in new cams/clutch/flywheel etc and now when the car is on idle and is reved its got this ticking as if its metal on metal. any ideas as to what this might be. seems like its coming from the top end.
Need your help guys.
Tks
Chris
bigblock
cali
have someone put the clutch pedal in while you listen to the engine. if the rattling stops its the throw out bearing. could also be your cam chain tensioner. i put in an pair of 3.0 cams in my 3.2 from a 180k sho. the chains were really dirty and almost looked like they were stretched (im lazy) . the car has made a ticking noise from day 1. im sure it that. you might have the same problem. if you can get yourself a mechanics stethoscope it will help you track down the noise faster.
shonuffmine
wildchild
sweating balls in fla.pan
X2 on the cat! i had on that sounded like it was in the motor, but once i got it on the lift it was clear as day that it was the cat!I wedged a screw between the inner n outer shield n VIOLA all done:wave:
