ScotSHO
I have had my 99 SHO for about 7 months now and I have just started having a problem that has cropped up a couple of times.
99 SHO (Paul Fisher's & black92's old car)
Welded cams
83k miles
New battery 12/05 w/ good clean terminal connections
Stock stereo system (so no wierd battery draws)
No VAK (I don't think, but where can I check under the hood to verify?)
Battery light does not come on at all...
It has happened once when I arrived at work (last Wed), and once when I pulled in the driveway at home (last night). When I stop the car and put the shifter in park, the lights dim and the car stalls. When it stalls, all of the accessories and lights go dim for a second too. Last night when this happened after the car stalls, the wipers cycled once, the clock was reset to 12:00, and all of the accessories came back on within 2 seconds. The car starts right up and does not exibit the same problem, although I only kept it running for maybe 5 minutes afterwords. I have noticed that leading up to this, when the brakes are pressed, all of the interior lights dim and the radio may pop like the power was cycled very fast. Normally, the brake lights do not dim the electrical system at all.
I have my own ideas, but I don't want to lead you guys. So what do you think could be failing?
Welded cams
83k miles
