HopefulSHO
111 System Pass
211 PIP circuit fault.
214 CID circuit failure.
542 Fuel pump secondary circuit failure.
538 Operator failure (I can't seem to run the cylinder balance tests for some reason. doh. I'll have to try again sometime.)
If any of you read my post from yesterday you know where I'm at. My car runs like butt sometimes - like only half the engine is firing. Bucks like a rodeo. But when its not doing that, it runs great. Keep in mind my tach works fine during all this - the only time it didn't was for a few seconds right after I started my engine once...I've searched through the forums and I'm gonna check all my grounds today. After that, I guess the camshaft position sensor? Then the crank sensor if that dosent fix it... I need to get well aquainted with my engine anyway
Any thoughts? Similar experiences?
Thanks for readin
Oh yeah, I can't get enough of this guy.. burn_out
Jeremy
Thanks for readin
Jeremy
