Ran codes...now what?
Blast7
Rochester, NY
I ran the codes that my SHO has been showing and hear are the results...
41--HEGO sensor circuit indicates system lean (rear)
83--'90-91: Low speed primary fuel pump circuit failure
91--'90-91: No HEGO switching detected (front)
I have two new O2 sensors that I can put it but what is the plan of action for code 83? Is my fuel pump bad?
projectSHO89
SHOless In St L
Fix the O2 sensor codes, reset the codes, then drive it again. Very possibly a transient code, otherwise, under the alternate codes in the Probst manual, it lists a failure in the high Speed Cooling fan circuit as a cause.
It is necessary to determine if this is a KOEO code or a Stored (Continuous) code.
Steve W
Blast7
Rochester, NY
I will replace the O2 sensors and get back to the forum probably later in the week. The code is a KOEO code.
shobroooo
