radio install
40BelowSummer
Puerto Rico
It is very easy to get the wrong kit, I got like 3 different ones before I just decided to get the amp bypass harness and have the stereo power the speakers instead of the amps.
Sorry Im not of more help but that was my scenario
benharper
Resident Squid
Stuarts Draft, VA
it's the right kit, right connector, just not fitting for some odd reason. anyone else run into this? Thanks
kickeralpine
ohio
i install radios is it the prem harness if so take a small screw driver and bend the pins back a little and it will go dont try to jam it in because it will push the pins out just got to play a little
wood_e
The dude
Ames, IA
Yeah i had some trouble, Just bend the pins slightly until you get them to fit right.
benharper
Resident Squid
Stuarts Draft, VA
i was thinking of that. it is premium. i just wanted to see what you guys thought. thanks :thumb:
