Radiator
SHOemup
Dalton, PA
I have to replace the radiator on my car. Any idea how much it's gonna cost me and how difficult the job is. I hear its not as easy as it sounds. Thanks
Chris
Chris Reina
"Don't drive like you own the car, drive like you own the road!"
AIM=turbochris12
93 MTX stock
emerald green
filler decals
Yamaha emblems
106k
Lund Headlight Covers
Lund Tailight Blackouts
SHO window banner
Tinted Windows (20%)
Vent Shades
Big wish list!!
It's easier than it sounds. All you have to do is remove the cooling fan shroud (Bolts at the corners and the electrical connectors), the upper and lower radiator hoses and the two radiator support brackets at the top of the bulkhead. Since you have an MTX there aren't any transmission cooler lines to the passenger side end tank. The radiator will then lift right out. There are only pins inserted into rubber bushings to secure the bottom of the radiator. It is really an easy job.
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
bigsho
sterling va usa
I bought mine for 112$. Ford list is about 250. Try a local auto store first.
Robbie
95 MTX red
SS SNORKEL
24 and 26 sway bars on floor
crystizel
